Aller au contenu principal
Repair and service information for the LG TrueSteam clothes dryer. Model numbers DLEX3570V, WM3670HRA, and DLEX3570W for graphite, red, and white colors respectively.
How do I set the machine to rinse in COLD water only?
Thank you for solving my problem with my washer’s CL. I was very frustrated trying to do it on my own.
On another matter with my GL4000 is how do I set the machine to rinse in COLD water only?
Répondre à cette question J'ai le même problème
Indice 2
1 commentaire
Easy. After choosing CYCLE (regular, quick, etc) tap TEMP until it cycles to TAP COLD.
par
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Hi,
Did you mean an LG WM4000HWA?
Not sure if you mean select a cold water rinse or run a cold water rinse cycle only.
Here's an image taken from the user manual that shows how to select a rinse and spin cycle only.
It also shows that all rinse cycles are normally done in cold water.
(click on image to enlarge)
Indice 1
5 commentaires:
FWIW, I am having an issue with my brand new LG using hot water for rinses. I definitely have the hot water connected properly. I've triple checked. So it could be an issue with the washer.
I found this question searching to see if maybe there is something I'm missing before contacting LG because my clothes are hot when I open the machine after a wash or even just a rinse cycle.
par
@andreasoper
What is the model number of the washer?
par
I’m having the same issue. Even the gentle cycle set on cold does a warm rinse & there doesn’t appear to be a way to set a cold rinse. I have LG ThinQ model WM3600HWA.
par
@gaileelliott
Did you try the "tap cold" temperature option at all?
According to the user manual on p.29 "All rinses use unheated cold water" so if yours never does regardless of the temp setting i.e. tap cold or cold, contact LG as it isn't doing what it should do.
par
I followed the directions in the posted image and press temp until it reads tap cold, however, the clothes come out warm/hot showing the rinse was warm. It is shrinking my clothes. It seems to be a common problem with LG - not a user friendly machine so far. LG Model 3400CW
par
Indice 0
2 commentaires:
Doesn't work still rinses warm/hot
par
No matter what we Select our LG washing Machine always rinses warm/hot. We have tried everything to stop this.
par
Ajouter une réponse
fcmolanphy sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 21
30 derniers jours : 93
Total : 5,687
