W123 m115 200 petrol - oil leak from distributor
Hi hope all is well
I have an oil leak when driving from the base of the distributor I changed the o ring last year but have been told the shaft doesn’t actually need an o ring
Any ideas of clarification
link to picture of where it’s leaking the shaft and Bosch diagram
https://freeimage.host/i/XNzwns
https://freeimage.host/i/XNEla9
https://freeimage.host/i/XNE0ve
Thanks in advance
Update (05/30/2022)
Update : looks like it’s leaking from the distributor shaft housing
Looks like there is an o ring there, didn’t know housing had an o ring? also I tried to undo the bolt but couldn’t crack it open is it ok to give it a strongman torque on it?
https://freeimage.host/i/XOFXzx
5 commentaires
@jonpasco the bolt that clamps the distributor in the shaft? Should be okay but not sure why it has seized. Should be a normal through the hole bolt. Don't strip it ;-)
par oldturkey03
It’s the housing one that goes into the block. (Where the dizzy sits into) Will try and keep my strong man skills to a minimum thanks for the tips @oldturkey03
par Jon
Ok after changing the o ring it’s still leaking but from the base where the shaft is mounted on the block. Mmmm baffled checked oil levels all fine checked breather hose incase of pressure etc all clear…
Mmm any other suggestions?
par Jon
@jonpasco time to dig down deeper. Let's see if the engine manual shows if there is an O-ring on that "tube" I would not be surprised if there was or at least a gasket. You getting into some heavy teardown :-) Just to verify, it is a M115 200 engine correct? You got a model year? Just to make sure.....
par oldturkey03
Always an adventure! Yes that’s it M115 200 123.020 1979
Can’t see anything in the manuals about a gasket on the housing bracket.
par Jon
