No cold water on wash but rinse is fine
I have no cold water going into the machine on the wash cycle. Rinse cycle fills just fine with cold. Took hoses off and checked inlet screens—they are fine. No problem with house supply. Anyway like I said there’s cold on the rinse but none on the wash.
9 commentaires
Hi,
What is the model number of the washer?
par jayeff
Model number is MVWB300W02
It definitely seems like an electrical or computer issue.
par Martha Wright
that sounds like corrosion on the valve not allowing cold and hot water in that or some gunk in there blocking the flow i need more info
par hay yew
do u have heavy water or high content of minarels in the water such as calcium, sulfides, or even led cuz that can do the same thing too over time
par hay yew
Martha Wright which wash cycle are you using? If it has cold in one cycle but not the other, it is unlikely that this is a water supply issue. This sounds like a wash program issue.
par oldturkey03
Voir 4 commentaires en plus
