Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Sixième génération de la montre connectée d'Apple, avec connectivité cellulaire en option, commercialisée le 18 septembre 2020. Modèle A2376, 44 mm.
Identifying Cable in Apple Watch Series 6
Hello! I'm trying to identify the third black strip when you first open the watch that isn't a part of the display flex cable. I'm unsure if it's just tape or a cable. Can someone help me identify what it is?
Update (06/25/2022)
The watch is currently taken apart to replace the display flex cable, but this is a photo of where it disconnected.
Répondu ! Afficher la réponse J'ai le même problème
Indice 4
6 commentaires
Sara - The grounding cable alone is replaceable!
Loosing the two screws which hold the thumbwheel assembly and then sliding in the new cable as its caught by the bracket (don't forget to take the small piece thats still there)
par
Thanks! What do you mean by “small piece that’s still there?”
par
@Sara Lenz =- Once you unscrew the thumbwheel assembly screws a bit use a tweezer to pull the small piece caught under the bracket. Trust me there's s fragment still caught in there.
par
Ah, gotcha! Thank you so much!
par
I can’t seem to find a replacement part when searching for “grounding cable” - is there another name for it?
par
Afficher 1 commentaire en plus
Ajouter un commentaire
2 Réponses
Solution retenue
Here's a better picture of the display cables
And now with the cables disconnected from the display unit
The thin cable is a grounding cable to link the displays ground to the watch bases ground. This has two functions one to dissipate static discharge you might have and to control EMI noise
Its anchored within the crown wheel unit and the foil sheet which is applied to the back of the display.
Update (06/25/2022)
Here's another view so you can see how the cable is attached to the case
Indice 4
4 commentaires:
Super helpful; thank you! I’m concerned this cable is damaged and there aren’t any DIY repair videos/instructions out there relating to it.
par
@Sara Lenz - Did it become detached? Post a picture where it's damaged.
Also don't forget to score and accept the answer if you're set - Thanks!
par
Bringing this back -- I also damaged this when replacing the screen and hoping to get a replacement for this but I also can't find one on ifixit or anywhere else on the web. Anyone have any luck?
par
@melinajefferson - Apple doesn’t offer parts and even the part houses don’t have much for the watches.
Depending on the damage it may not matter as the cover shield still works with one leg. If both are cut then you made to get a new shield piece. If the data ribbon cable is damaged that’s really the end of the watch as The whole logic unit (SIP package) will need to be replaced as the cable is not offered as a part.
par
Anyone can help identify what is this? and what its for? Tq
Indice 0
1 commentaire:
Did you get the answer? I am also wondering what is this for.
par
Ajouter une réponse
Sara Lenz sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 18
30 derniers jours : 113
Total : 2,865
