Hose not snapping into place
My Hoover Windtunnel 72400 hose will not snap into place anymore. This makes it extremely difficult when trying to vacuum because the handle pulls out when you pull the vacuum towards you. How do you fix this specific problem. The suction on the vacuum is fine.
I have the same problem the tiny retention stud is broken and handle of tube swivels and comes out.
par martin hynes
Did you ever get the problem solved? Mine has same issue, it's like a metal brad/button that holds the pole in place. Vacuum works fine, just a pain...duct tape only holds for so long 😂
par Leslie K Mitchell
