Connecting to Modern TV
Hey! I was trying to connect my NES to my TV using the composite ports, but it won't work. Any suggestions?
If the TV has composite ports and the NES has composite ports and you connect the RED to RED, WHITE to WHITE, YELLOW to YELLOW and set the TV input to the composite ports everything should work.
If it does not, then either the NES isn't transmitting, the cables are bad, or the TV isn't receiving.
To figure out which is a matter of substitution.
Connect to another TV. If it still does not work, then it probably isn't the TV.
Connect a different set of cables. If it still doesn't work, then it is probably your NES.
Thanks, I will try it.
I had the same issue with my LG tv. I bought this CONVERTER from amazon and it works great! still cant play duck hunt on modern tv's though =(
I know. It's an unfortunate side affect from switching to LCD/LED. I might buy the converter.
Dernières 24 heures : 6
7 derniers jours : 21
30 derniers jours : 113
Total : 824
1 commentaire
Hi @a_commodore_fan,
What is the make and model number of the TV?
par jayeff
