Getting a code F:01
My washer starts then stopes with code F:01 and I don't know how to reset it. Never had any problems with the machine in 5 years.
Model # MVWB450WQ0
Model # MVWB450WQ0
Hi,
Here's the Tech sheet for the washer.
Run the Automatic Diagnostic Test mode as described on p.1 to verify that the error code is an F01.
If it is then on p.3 it indicates a Pressure Signal Out-of-Range problem - see possible causes.
If the pressure hose is OK go to p.4 Test #3 Motor Circuit to see if you can determine whether the motor or the MCU (Motor Control Unit) is the problem.
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 9
Total : 138
