Aller au contenu principal
Mis sur le marché le 21 septembre 2018. Modèles A1921, A2101, A2102, A2104. Disponible avec GSM ou CDMA / eSIM ou nano-sim / 64, 256 ou 512 Go / Argent, Or ou Gris sidéral. (Se prononce "iPhone 10 S Max".)
How to remove the Passcode with out losing data?
I’m the owner of the device and the Apple ID being used on the device I just forgot the passcode from it and it’s also currently with the “iPhone disable connect to iTunes ”sign from trying every number I could remember lol 🤦🏻‍♂️
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
3 Réponses
Réponse la plus utile
use 3utool and reflash with retaining user data
Indice 1
3 commentaires:
The device is in disable mode would I have to get the device into dfu mode for the device to connect to 37tools and follow your suggestions?
par
@taco18 dfu or recovery mode
par
@tech_ni thanks for your help I tried following the steps to get the device in DFU mode, then flash process maintaining user's data I still find myself in need of a passcode even on the attempt to retrieve user's data and once I use a passcode I believe it's correct the phone gets into an iPhone unavailable try again in some minutes. If there's anything you know I should do to get rid of the passcode please help once again
par
Put it into dfu. Recovery resets after 15 minutes turning the phone on losing the connection to pc, dfu doesn’t.
Indice 1
Waimond michae
Update (11/14/24)
Sign out apple
Indice 0
1 commentaire:
Sign out apple
par
Ajouter une réponse
Taco sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 192
