Aller au contenu principal
Pour réparer ensemble - Je crée un compte
A home electrical installation is a complex system of electrical components that bring power into a home and distribute it to the various outlets, appliances, and lighting fixtures.
Issues Testing an Imperial Electric Permanent Magnet Motor
I've come under the possession of 3 Imperial Electric motors:
Model: P66LR006
Volts: 36 VDC
Amps: 100
HP: 1.3
RPM: 2100
Before selling them I've been trying to test their function. I have three 12 VDC batteries that I can wire in series to obtain the 36 VDC but want to make sure I'll be doing this correctly.
My questions relate to the DC voltage mostly.
#1: Since I do not have the controller for this motor (came off a floor scrubber) would the best way to test this be applying a lower amount of VDC and slowly ramping it up to 36 VDC? What type of electrical device in series with the batteries would be able to do this?
#2 These motors ask specifically for lead acid batteries. I'm not very familiar with testing electric motors in this way. Would a car battery be a bad idea to utilize in the testing method? Do Crank Case Amps have any negative effect on a permanent magnet motor?
Obviously I need to learn more about DC voltage in relation to electric motors and any help here is much appreciated. Thank you.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Hi @mr_paule
Looking at the compliance plate on the motor you would need a voltage/current supply and controller capable of handling the current and voltage required by the motor.
I don't think that a 12V car battery would suffice as most can't supply the necessary current i.e. 100A (as shown on the plate - see image) or the voltage. Even with 3 car batteries in series to get the required 36VDC you still wouldn't have enough current available to fully test the motor.
(click on image to enlarge)
Indice 2
Ajouter une réponse
Luke Paule sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 12
Total : 293
