Aller au contenu principal
The 250 G4 laptop is aimed for small businesses designed by HP and initially released in 2016. Repair guides and detailed device information can be found here.
5 questions Voir tout
How to fix Touchpad, Replace or clean it?
I need help on how to fix my laptop touchpad
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
2 commentaires
Hi Gilbert,
What kind of problems are you having with the touchpad? Knowing that will help the rest of us try and figure out the best way to help you.
par
@dadibrokeit my laptop is HP 250 G6 and the touchpad is not working I already tried downloading the latest drivers but its still not working
par
Ajouter un commentaire
1 Réponse
Solution retenue
Hi @onionshake
What is the status of the touch pad in Device Manager?
Go to Device Manager > Mice and other pointing devices > right click on the touch pad entry > Properties > General tab. In the Device Status box, does it show "This device is working properly"? If so then there's a hardware problem with the touchpad, e.g. faulty touchpad, loose cable etc.
Here's the maintenace and service guide for the laptop. On p.79 is shows that you have to completely dis-assemble the laptop to get to the top cover/keyboard assembly so that you can access the touchpad.
If it is determined that it is faulty, I'm not sure if you can get a separate touchpad or if you have to get a complete top cover/keyboard assembly which includes the touchpad. The country specific part numbers for the top cover assembly are also found on p.79. Search online using the part number only appropriate to your model to find suppliers. Usually the part number can also be found somewhere on the underside of the assembly if you wish to verify the number.
Indice 1
Ajouter une réponse
Gilbert Busilig sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 409
