The reason why the battery is not charging
I repeat my question a little more clearly, what I want to know and the reason for it, I would appreciate an answer for it.
I have a 4-IN, regular connector USB and, 1-OUT Mini USB connector for use in my APPLE Minibook and use on it.
If it possible to charge the computer's battery. also and I want to know if the position of the + and - voltage connections, if they are in both compatible between the output and input of one and the other. The reason is that the original adapter does not give me a charge for the battery and I want to solve this question. to make a decision.
Lithium-Ion batteries require a proper charger, you can't use the USB-A or mini-USB connections for a power source, first they don't offer the needed power to charge your battery and don't have the needed control logic your USB-C charger does.
So simply put you can't do what I think you are trying to do.
Truly, the best answer is to find a friend who has a charger (any USB-C charger) and get the meter I pointed you to so you can first figure out what has failed.
par Dan
