Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
5 commentaires
Hi,
What is the make and model number of the hair dryer?
Check the back of the hairdryer. Sometimes there’s like a mesh that gets clogged up restricting the flow of air through it, if it doesn’t get enough air flow it will start to overheat.
Does you hairdryer have a screen for filtering out debris going into the unit? Did you check for hair getting past it, entering the heating element and cooking hair? Cooked/burned hair usually results from the unit ingesting hair and creating the terrible smell.
@strongbow, blocking or restricting airflow tends to allow the heating element to create hotter air temps without burning but any debris like hair getting into a hair drier will burn and melt creating the bad odors.
5 commentaires
Hi,
Does it have a "burning" smell?
par jayeff
par [deleted]
par F Dryer
@notbroken you’ve just wrote what I said 😂
par [deleted]
par F Dryer
