Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Processeur 1.4GHz ou 1.6GHz, SSD de 64 Go or 128 Go.
A1370 MacBook Air will not boot with/without battery
I have a Late 2010 11-inch MacBook Air that my aunt gave me to repair and I am having difficulty seeing if it will boot up or not. I found out that the battery has swollen in the machine so I had threw it out to prevent a fire or explosion. After that, I plugged in the machine to see if it would boot then but it still won't. I tried resetting the SMC and also pressing down the power button, then plugging in the power adapter, still holding down the power button. Nothing worked. Is there something wrong with the logic board or I/O board? After plugging in my 85 watt power adapter, it just shows a green light continuously. Sometimes it will show a dim green light. Please help, thanks
Here are picture of the boards
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Solution retenue
First a 85Watt unit is too much for your system you need a 45W MagSafe 2 Power Adapter for MacBook Air. It also sounds like you have a deeper issue with either the MacBook Air 11" (Late 2010) I/O Board or within the charging logic in the main logic board.
For now lets get a good set of pictures of the I/O board so we can check the contacts and look for corrosion Ajout d'images à une question existante. Follow this guide MacBook Air 11" Late 2010 I/O Board Replacement
Image Replace an I/O board compatible with the Late 2010 model MacBook Air 11 inch laptop. Fix problems with charging, audio, and data connections. Includes the MagSafe power, USB, and audio ports.
Produit
$29.99
Image MacBook Air 11" Late 2010 I/O Board
Tutoriel
Difficulté :
Modérée
Image iFixit
Tutoriel
Difficulté :
Très facile
2 - 5 minutes
Indice 2
12 commentaires:
Can it still work with a 85 watt power adapter or do I have to buy a 45 watt one?
par
I added the pictures of my I/O and logic boards
par
@mahzak09 - Almost! You'll need to take it out and take the other side and the MagSafe connector so we can check it as well.
par
Added bottom of I/O board
par
@mahzak09 - One more! the MagSafe connector face where the cord connects
par
Voir 7 commentaires en plus
Well this video might help you in fixing: Macbook Air 13 2012-2017 , Will start without battery but wont start with it
Indice 1
Ajouter une réponse
MZQK sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 16
30 derniers jours : 40
Total : 659
