Aller au contenu principal
A1418 | EMC 2889 | Late 2015 | 1.6 GHz dual-core Intel Core i5 or 2.8 GHz quad-core Intel Core i5. Released October 13, 2015.
20 questions Voir tout
Will any A1418 screen replacement work with this model?
Why doesn't this site carry replacement glass for this model? All of the replacement glass I've gotten back from search are so much more expensive than the older models.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
Excellent resource. It told me the screen would also not work with 2012, 2013 & 2014 models. Thank you!
par
Ajouter un commentaire
1 Réponse
Solution retenue
iFixit doesn't carry every possible part! They just couldn't as its quite bit of expense to do so. As far as why the costs are higher for the 2012 and newer systems has to do with the complexity of the display, The newer Thin series systems use a custom laminated design vs the older cover glass and discrete display panel which was standard.
There are two versions of the display depending on which system you bought! The Standard or the 4K
Make sure you get the correct one! The logic boards are different as well as the connections.
Indice 1
Ajouter une réponse
Roy sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 6
Total : 163
