My left speaker is popping
I recently bought a Macbook Air off of eBay,and it has no issues other than the left speaker making a popping sound ever minute or so,and I do not know how to fix it.
Hi
You will need to get a closer look at things
I would open it up and look at the speakers,check for any debris or metal shavings around the speaker and if the speaker looks clean try and clean both connector and board connector with isopropyl alcohol and reseating the speaker connector by following the guide that corresponds to what speaker you think has the issue
Remplacement du haut-parleur droit du MacBook Air 13" début 2017
Remplacement du haut-parleur gauche du MacBook Air 13" début 2017
If it doesn’t work you will need to replace the speaker that has the issue
If you let me know what region you are from I can help get you some replacement speakers
Hopefully this helps
Any questions please ask
Tutoriel
Difficulté :
Modérée
Tutoriel
Difficulté :
Modérée
15 - 35 minutes
Thank you so much for your answer! I will open it up soon and take a look at both speaker connecters to make sure there is no dirt and make sure that they are seated correctly. I am in the United States btw. :)
Okay,thank you!
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 40
