Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Xiaomi Redmi Note 9 est un smartphone de milieu de gamme de Xiaomi, sorti en avril 2020. Il dispose d’un écran LCD IPS de 6,53 pouces, d’une caméra arrière principale de 48 MP, d’un capteur d’empreintes digitales situé au dos, d’une batterie de 5020 mAh et fonctionne sous MediaTek Helio G85.
Device reboot continously when in Standby-mode
Good Morning,
i have the phone of my mother in law and it's rebooting continously when in standby. as long as the display is on, you can use the phone normal, but after locking it device starts to reboot again and again. did someone have this before?
btw: Chargng is a little bit slow, but i think it's because of the reboots (more power needed).
Répondre à cette question J'ai le même problème
Indice 1
3 commentaires
Have you tried to update software or firmware? It could maybe be a Internal Issue but im not sure what would cause it.
par
this is impossible, because when i tried it it fall back to bootloop at 64% Updated.
par
non of the above works i have tried power and volume+ button but it is not going on that
par
Ajouter un commentaire
3 Réponses
Réponse la plus utile
@m0ddmylife
What happens if you start the phone in safe mode?
If still no good, here's a link to the schematics which may help as it has Level 1, 2 & 3 repair instructions.
I haven't tried this link but have used the website before for other makes and models and they were OK.
Indice 1
Your smartphone might experience a reboot loop if its cache memory is full. To test for that possibility, you should empty your phone's cache
Regards,
Will
Indice 0
1 commentaire:
I've set it back to Factory mode multiple times, so this is not working.
par
i have a had the issue a couple times what i do to fix this is, is to hold the power button until the lock screen appears
Indice 0
Ajouter une réponse
Michael Kastner sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 37
Total : 1,467
