Aller au contenu principal
Pour réparer ensemble - Je crée un compte
The Canon Pixma iP3600 is a compact inkjet photo printer that weighs 12.3lbs and is 17.0”(W) x 11.7”(D) x 6.0” (H). This wired printer was released as part of Canon's Pixma series in 2008.
How to fix service error 5700?
paper jams on rear tray, using gloss paper or any other paper, can use front casset to run gloss paper system software will not aloud to run gloss paper from front casset
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
The error displayed on the Canon Printer number means the sheet feeder needs to be replaced, it can be that gears in the printer and/or sensor have become broken or faulty. 5700 is an ASF cam error most likely which is called an ASF cam sensor error
Regards,
Will
Indice 1
1 commentaire:
how do you fix the problem?, i know the fault, do i buy parts? do i addjust some thing on the printer? got a 'simplified service manual' to take covers off to fix it. need info of what to do, or how to it.
par
Ajouter une réponse
andrew simpson sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 26
Total : 1,007
