Aller au contenu principal
En juin 2017, Apple met à jour le MacBook Air 13" avec un nouveau processeur Intel Core i5 Broadwell, ce qui donne une légère augmentation des performances et de l'autonomie de la batterie.
404 questions Voir tout
Why my MacBook Air turns off Randomly
My laptop completely ran out of battery after 2 months of no use / no charging (I left it under the bed). When I tried to start it and didn’t work so I used the alt/shift/ctrl/power button technique. Took it a while but finally came back. Used it one day with no problems (plugged and unplugged) and the third day of use it started to shut down randomly (sometimes while loading the profile just after starting it). Is there any suggestion on what could be wrong or what to do?
Répondre à cette question J'ai le même problème
Indice 2
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi
When a device starts behaving like this it usually means that your batter is needing replaced
Leaving lithium battery’s sitting for a long time can cause them to degrade and stop working properly
Also the temperature and amount of battery cycles has a lot to do with it too
Here’s how to check your battery’s health(linked below)
https://www.coconut-flavour.com/coconutb...
If your cycles are above 500 and it says service anywhere that usually means that the battery is the issue
Here’s a link to the part you may need
MacBook Air 13" (Late 2010-2017) Battery
Hopefully this helps
Any questions please ask
Indice 2
2 commentaires:
I really find this app makes the information easier to read and brings it together in a simpler presentation CoconutBattery the free version is only you need.
par
@danj
Thanks for the information!
Il add it to to my answer
par
Ajouter une réponse
DanCas sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 6
Total : 55
