Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Panasonic RQ-2102 est un enregistreur à cassette portable fabriqué par Panasonic en 1994. Bien qu'il soit arrêté depuis longtemps, il reste un objet de collection populaire à ce jour.
Monitor port one sided?
I was wondering if the monitor port on the RQ-2102 only has audio for one side of earphones, or if I needed to see if I could fix whatever the problem might be on mine.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Hi Ridwan,
According to the Service Manual, the RQ-2102 is a monaural recorder, meaning it only records a single channel. So yes, you'll only get sound on one channel of your stereo headphones unless you use an adapter that connects that single output channel to both of the stereo channels. It's called a mono to stereo adapter; you'll need the 3.5 mm size like this one.
Monoprice 3.5mm TS Mono Plug to 3.5mm TRS Stereo Jack Adapter, Gold Plated - Monoprice.com
With one of those, you'll hear sounds in both ears instead of just one.
Indice 4
2 commentaires:
Hi Jerry,
Do you need to adapt both sides of the cable? (my headphones have a removable cable).
Thanks
par
@Matías Ruiz-Tagle, no, since your headphones are stereo, the adapter will feed the single audio channel to both stereo channels in the cord, so when they get to the headphones you'll get sound in both ears.
par
Ajouter une réponse
Ridwan Mujahid sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 15
Total : 685
