WA48H7400AW/A2 - Only fills and drains in a loop
I have a Samsung washing machine that will fill and drain, fill and drain, but never anything else. It never moves on to the different parts of the cycle.
I found this link very helpful:
WA48H7400AW/A2 not spinning during wash mode
I was able to get into the diagnostic modes and found the same code stored twice: E82
That points toward a MEMS sensor - which from what I've gathered has to with the vibration sensor. I'm guessing this has nothing to do with the cycles not going forward.
I also ran the quick tests:
- All water valves work, pumps work, lock works
- Spin mode goes all the way to 999RPM before shutting down
- 'Board Input' mode seems to show all the appropriate inputs
- I couldn't get the 'fast time down' test to work. I gather this, once you start a load, should move between the cycles more quickly than the standard program would do. Once I started the load, put in service mode, then pressed 'Temp.' it would beep but do nothing.
What other troubleshooting can I do to determine what could be going on?
