Note 8 Freezes and restarts
My Samsung Note 8, has started to Freeze and then restart and keeps doing that until it's battery runs flat, sometimes locks up so bad I can't force it off.
I did some troubleshooting from Wiping the cache partition and factory resetting the phone and seems to work for about 2 minutes before freezing and going back into the loop, I also tried reinstalling the software for the phone with Odin but seems that doesn't fix the issue.
Any help would be greatly appreciated!
Thanks in advanced.
5 commentaires
Hi @littletech
Does it do this with the charger connected?
par jayeff
Hey @jayeff
I've tried whilst charging the phone and its gone past the boot logo and started a fresh install (guessing from me factory resetting) then It went into the phone worked for about 3 minutes before freezing and restarting few times then works normally before freezing and repeating the loop before just shutting down.
Some extra info that might be helpful: I got the phone refurbished, seems its originally Korean based as the provider is LGU+.
par Littletechy
@littletech
Just eliminating things :-)
Try starting in safe mode and check.
Don't know anything about flashing new rom to get away from a Korean base but a quick read online seems to indicate that the partitioning is different so maybe it's getting confused if there's some remnant data left somewhere idk.
par jayeff
@jayeff
I tried in safe mode but unfortunately seems to continue to crash.
So i need to find a way to wipe the whole phone and then try reinstalling it all again?
thanks for the help.
par Littletechy
Was your problem resolved with a new battery? I've been having the same issues since the last couple of days...
par Bobby
