Aller au contenu principal
Processeur quad-core Intel Core i7 à 2,2 GHz (Turbo Boost jusqu'à 3,4 GHz), 2,5 GHz (Turbo Boost jusqu'à 3,7 GHz), ou 2,8 GHz (Turbo Boost jusqu'à 4,0 GHz) avec 6Mo de cache L3 partagé.
Questions au sujet de 720 Voir tout
New SSD not showing up
I installed a 500gb Samsung SSD in my MacBook with an Sintech adapter.
Unfortunately the SSD ist not showing up if I try to install macos.
I tried to check the terminal with diskutil list but there is no SSD too.
What I have to do to fix this?
Répondre à cette question J'ai le même problème
Indice 1
5 commentaires:
Did you try a more known adapter?
And what model Samsung SSD?
par
I have only this adapter and it worked when I first installed montery on it. After I formatted the SSD on my other Mac I can’t see it anymore. The Model is the Samsung 970 Evo plus
par
Does it work in the mac you formatted it in? This sounds like an OS file system compatibility issue. If the mac you formatted in has an older or newer os your current mac might not read it. You might have to put it into an enclosure and format it with the OS you currently have installed.
par
So I try to explain in more detail what I tried.
I first installed Montery on it old Mac when the SSD was new.
Then I removed the SSD and put it in an enclosure and formatted it as follows:
Format: Mac OS Extended (Journal)
Scheme: GUID Partition Map
The was to install Sierra now so I can install Linux as Dual Boot, because when Montery was installed no EFI was shown.
I tried to run the Sierra installer app on my new MacBook m1 but I always get the error message that the version is too old to run on the mac m1.
par
@zabuzza992 - The newer M Series systems require Big Sur or Monterey for the newest systems. You can’t run Sierra as that OS is strictly Intel not M.
Even still you don’t need to take that route using your M Series system to setup your older Mac.
par
Ajouter un commentaire
1 Réponse
Sounds like faulty SSD,
I recommend returning it (If possible)
And getting an OWC SSD, It would be better because it doesn't need an adapter.
Part: OWC Aura Pro X2 SSD
Guide: Remplacement du SSD du MacBook Pro 15" Retina mi-2015 SSD
Image OWC Aura Pro X2 SSD
Produit
OWC Aura Pro X2 SSD
$88.99
Indice 0
Ajouter une réponse
Voidl3 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 11
Total : 117
