Hi @hollywood3zx
They're supposed to get hot, but how hot may be the problem.
As the toast heats, the temperature will cause the thermostat's metals expand at a dissimilar rate and when the necessary level of heat is attained, the thermostat will curve sufficiently to straighten and open the contacts which will turn off the heating element.
You may have to check that there are no short circuits in the heating element which will reduce the resistance of the element but this will increase the current flow though the element meaning that the thermostat may get hotter than it should.
Bit hard to tell maybe if sections of the element are short circuit between the element wires, but you may be able to see if it is glowing or not uniformly over the length of the element or if there are any dull spots. A short circuit has no resistance so there will be no voltage loss at that point when the current flows through it so therefore no heat, no glow.
A lot of toasters get too hot to touch when toasting bread etc, so maybe try toasting a slice of bread and check that the thermostat functions correctly and disconnects the heater element, hopefully before the bread is burnt to a crisp.
A voté
Annuler
Indice
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
