Aller au contenu principal
The Meta Quest 2 (formerly Oculus Quest 2) is the successor to the Oculus Quest that came out on May 21st, 2019. The Quest 2 is a revised model that features a better processor and redesigned touch controllers.
Questions au sujet de 104 Voir tout
I accidentally spilled a small amount of water on my headset
I spilt a pretty small amount of water on my Meta 2 headset, it was working properly but now it isn't turning on. It still displays the powering on screen, but it won't stop. The controllers won't connect either, but nothing happened to the controllers.
Répondre à cette question J'ai le même problème
Indice 2
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi
Just like with all water damage please don’t try and turn it on unless for testing purposes as it can make the issue worse:-)
What I would recommend doing here is taking the device apart and having a good look for where the water got in,the sooner this is done the greater chance you have of your device working again!
Once inside and you have find where the water has gotten in ,carefully clean the effected area(there’s usually corrosion where the water got in)with isopropyl alcohol until the parts and boards are water and corrosion free
After making sure no other parts were effected you can plug it in and test but if it still doesn’t work ,it will need board level repair which isn’t easy unless you have experience in that sort of field
Here’s a disassembly guide
Démontage de l'Oculus Quest 2
And here’s a water damage guide(this one if a iPod but it’s the same process for resolving water damage)
Réparer un dommage causé par un liquide sur un iPhone
Hopefully this helps
Any questions please ask
Image iPhone
Tutoriel
Difficulté :
Difficile
1 - 2 hours
Image Oculus Quest 2
Tutoriel
Difficulté :
Difficile
1 - 2 hours
Indice 1
Ajouter une réponse
Karter Brown sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 20
Total : 52
