Why is my washing machine not pumping water out (correctly)?
Hi, I actually have a Haier Inverter Motor 7kg front loader washing machine but couldn’t see it listed.
I’ve recently moved into a new house and noticed my washing machine pump wasn’t draining, and I was receiving a ‘clr fltr’ message. I initially cleared my filter, turned it back on and still got the error. I then opened up the bottom of the machine and checked for obstructions in the tubing underneath, nothing.
So I tried something, I disconnected my pump hose from the outlet under the sink, and ran the machine on a spin cycle, all the water came out quickly and without issue, so I’m 99% sure my drain hose isn’t clogged or obstructed. Is it possible somethings wrong with my plumbing? There’s no kinks in the hose however it does have to run down and then slightly up again to reach the connection.
Any help at all would be appreciated as I’m completely lost.
