Aller au contenu principal
The smaller of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
20 questions Voir tout
Is MacBook Air 2012 screen compatible with 2013?
I bought the A1465 screen to fix the MacBook Air 2013 screen.
But it was the screen of the 2012 model and I know that the iSight camera cable doesn't compatiable
also, I don't need an iSight cable.
However ,the display and Wi-Fi cables look similar, are they compatible?
Répondre à cette question J'ai le même problème
Indice 1
1 commentaire:
@dogsuand2su the LCD's should be compatible. what is not are the iSight cables, WiFi cable. Those do have different length, connectors etc.
par
Ajouter un commentaire
1 Réponse
Sadly, the cables are a different length between the 2012 and the newer 2013~ Early 2015 display assembly’s. Which you can see in these two images.
The raw LCD panels are the same, but it’s a bit of work to open the assembly to replace it. For a frame of reference here’s a MacBook Pro panel replacement yours is a bit different but it gives you an idea what’s involved Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2009
Image Replace a display assembly compatible with the MacBook Air 11" Mid 2012 model A1465 laptop. Part #661-6624. 11.6 inch. 1366 x 768 Resolution.
Produit
MacBook Air 11" (Mid 2012) Display Assembly
$249.99
Image Replace a display compatible with the MacBook Air 11" Mid 2013 to Early 2015 model A1465 laptop. Part #661-7468, 661-02345. Includes the 1366 x 768 pixel 11.6 inch LCD screen, display cover, bezel, iSight Camera, clutch hinges, Wi-Fi antenna, iSight, and display cables.
Produit
MacBook Air 11" (Mid 2013-Early 2015) Display Assembly
$164.99
Indice 0
Ajouter une réponse
minjae kim sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 33
Total : 324
