Aller au contenu principal
Why does my headphone keep going low so fast even when I charge for ho
For the past few weeks I noticed my headphone has been showing some strange signs lately and I don't seem to understand what's going on
When I charge it for hours,I only get to use it for less than 3 minutes.please how can I tackle this?
Thank you
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
2 Réponses
Hi @aced_one
Do the earbuds show as being fully charged?
If so the batteries in the earbuds may be failing and need to be replaced. It happens, even rechargeable batteries have a life span.
Can't find a teardown video online but here's a video that may help.
Once you have opened the earbuds, look for the model number of the battery (printed on battery) and then search online using that information to hopefully find suppliers.
Indice 0
1 commentaire:
Thanks I think I'll stick to this for now
par
There are a few things that you need to check for:
1. When you put the earbuds in the case, does a white light appear. That light indicates whether or not the earbud is charging.
2. What percent does your phone say the earbuds battery level is at? That will let you know whether the battery of the earbud is actually being charged.
Often times the issue is that the copper charging contacts on the bottom of the earbud and the case become obstructed by lint and grime preventing a proper connecting from being made.
For the earbuds, try to find something thin enough to fit in the those holes and glenty clean off the charging contacts. I used a tiny flat head from my mini screwdriver set that i wrapped a small piece of papertowel around.
For the case, i stuck a small piece of paper towel into the earbud well and used a plastic spudger and pick tool to get down there to clean out ant grim
Indice 0
Ajouter une réponse
Harrison Essey seun sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 23
30 derniers jours : 96
Total : 1,675
