Hi @darrenmill56100
No heat and everything else working OK, indicates a problem with the HV (high voltage) circuit in the oven.
This could be the R2 relay on the control board, the HV transformer, the HV diode, the HV capacitor, the magnetron or the wiring between these components.
The R2 relay contacts when operated connect the AC power to the HV transformer primary winding. The transformer in conjunction with the HV diode and the HV capacitor generate the necessary voltage for the magnetron which produces the microwaves which heat and cooks the food as they pass through it.
Here's a link that describes how to test each of these components in the oven.
Here's a link to a parts supplier that is useful as it has the wiring diagram for the oven as well.
If you find a component which is causing the problem, locate it in the parts list to find the manufacturer's part number listed with the part. Then search online using the part number only to find suppliers that suit you best.
FYI your oven is a Frigidaire oven made for Kenmore. Just so you're not surprised when the parts show up as Frigidaire parts. As best as I can tell, Kenmore doesn't make appliances but presumably orders them from other makers e.g. LG, Whirlpool, Frigidaire etc and then renames them.
Also see the safety notice in the Chosen Solution above, regarding working in microwave ovens.
A voté
Annuler
Indice
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
1 commentaire
Unplug the microwave from the power source, and give it some time to discharge any stored electrical energy. This is akin to waiting for a storm to pass before venturing out onto the sea.
Next, remove the microwave's outer casing. Much like an archaeologist delicately unearthing a precious artifact, use a screwdriver to remove the screws that hold the casing in place. This reveals the inner workings of the microwave, including the fuse.
par Kamran Waiz
