LG refrigerator light is not turn on
Try these troubleshooting methods: https://www.youtube.com/watch?v=NI0t5QVf...
Hi @rickmccoy
Looking at the service sheet for the model series, an E C0 error (if this is what you meant) is a communications problem between the main board and the display board, - see #18.
Maybe check the harness plugs on the cable that connects between both boards (both ends) to see if there is any corrosion on the contacts or if they're loose etc.
Here's the start of the LED lamps troubleshooting flowcharts but if none of the lamps work it may be more of a main board problem as there is also a communications problem associated with the main board as well i.e. error code, rather than a LED wiring cable, door switch or LED lamp module problem, but I suppose you may have to eliminate the possibility that it may be individual faults for each lamp first.
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 18
Total : 260
4 commentaires
Hi @loveneeshtayal,
What is the model number of the refrigerator?
Have you checked if the light globe is OK, you didn't say?
par jayeff
their are several, their led lights, none of them work...
par Rick McCoy
@rickmccoy
par jayeff
lrmvs3006s /02 "plus error CO E" I noticed a red light flashing 8 times too on the main board
par Rick McCoy
