Is there a maintenance guide for this laptop I can consult (add SSD)?
Hi, I'm looking to add a second SSD to this laptop, as it has a second 2208 slot.
As I'm quite new to tinkering with laptops I'd like to consult some kind of guide on how to open it up, how to install the second SSD, and what kind of SSD it supports?
Thank you very much in advance!
2 commentaires
After removing the screws couldn't get the bottom part out. Should there be applied some heat or something? This seems to be glued in or something
par Tommi Grönlund
I know this reply is late, but after removing the rubber feet from the bottom of the laptop, they can be squeezed back into their positions when finished, unscrew all the screws. Then use a shim to help you lift a corner of the laptop, the bottom is clipped in, carefully move around the perimeter with the shim, unhooking the clips. Then you'll have the bottom off the laptop and should see the free NVME slot.
par Cameron Malchow
