Le Moto E4, également connu sous le nom de Motorola Moto E 4e génération, ou sous les numéros de modèle XT1765, XT1766, XT1767 et XT1768, est sorti en juin 2017.
I dropped my phone and the entire screen went black.
I received a hand me down moto a little while ago that already had a couple of cracks it it. And today I accidentally dropped it and the camera broke. And the screen also went black. I know it still works because I feel the device vibrate when I press and hold the power button. Which would indicate that it was asking me if I wanted to shut the device off. What tf do I do????
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
1 commentaire
You could try (blindly) tapping the correct places on the screen, if it is still registering taps, to first enable dev mode, get into dev mode, enable usb debug, then connect to a computer and use ADB and scrcpy to render the screen on your desktop. To take this route it would help to get ahold of someone with another E4 that can take images of every step (importantly every tap and swipe with exact motions, skipping nothing), perhaps with a ruler next to the device such that you can then recreate the motions on the blank screen. Of course, thats only if it still registers taps...
While there is a small possibility the display connector has gotten disconnected as a result of the drop, it's far more likely that the fall has exacerbated the existing screen damage and put the final nails in the screen's coffin.
If it was my phone, the first thing I'd do would be to follow the screen replacement guide up through Step 5 where it shows how to disconnect the LCD connector. Unplug the connector, clean both sides with 90% or higher concentration isopropyl alcohol then reconnect it. Reassemble the phone and see if that's made any difference.
If, as I suspect, it still doesn't show a picture, then you'll need to source a replacement screen and follow the guide the rest of the way through to replace the LCD. Don't forget to purchase precut screen and rear case adhesive sheets so it'll stay together when you reassemble it. Just as a tip; I usually buy a couple when I need them; they're quite inexpensive and unfortunately all too easy to mess up, so having extras on hand saves you from having to wait while you reorder if you do get them tangled up and unusable.
If your phone is the model with the fingerprint sensor let us know and we'll see if we can locate the correct guide for that phone since the guide I pointed to specifically says not to use it if your phone has the fingerprint sensor.
1 commentaire
par Tracy Bueller
