Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Lancé le 20 septembre, le plus grand et plus cher smartphone Apple de l'année 2019 impressionne avec son écran OLED de 6,5 pouces, sa caméra à triple objectif et l'amélioration de l'autonomie de sa batterie. Il succède à l'iPhone XS Max.
I purchased an Icloud locked iPhone no refund need help unlock icloud
I have a A13 running IOS15.6 which i ordered online used , was advertised unlocked and did necessary calling for a refund and completely sruck out, listing was gone no more contact information on the site about the seller. Unfortunately phone is icloud lock and i don't have money to pay for it to pay for unlocking service. My question is any free Software online or freeware site i can use for removing Icloud lock for free of course will be a blessing please.
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
Ajouter un commentaire
7 Réponses
Solution retenue
@patrickatt38737 there is no way bypassing iCloud lock. No software, no hardware is going to accomplish this. The commercial services that offer this are going to get your phone to maybe the equivalent of a tablet, but never a phone again. You either need the original owners access or Apple to unlock it. Sorry. no other way to remove the iCloud lock.
Indice 10
2 commentaires:
I completely understand your frustration, but it's true that bypassing the iCloud lock is not possible through software or hardware methods. The commercial services claiming to do so may only provide limited functionality. In order to remove the iCloud lock, you would need either the original owner's access or assistance from Apple themselves. I'm sorry, but there isn't another way to bypass the iCloud lock.
par
Technically you can get a iPhone with iCloud locked unlocked without apple or the owner. It just wouldn’t require these fake software companies try to scam people. The only other way without apple help or the owner is to buy a cheap smashed spears and repair iPhone same model cheap make sure it don’t have iCloud lock then put the mother board from that spears and repairs iPhone into your iCloud locked phone and you have a working iPhone without iCloud
par
iCloud locks are tied to the S/N, and everything bordering on the kitchen sink is going to be paired with parts serialization so that makes swapping the board hard to remove this lock without getting what is essentially a donor phone with cracked rear glass you can use this phone for as a donor phone. You have a bum phone, take it up with eBay and force a refund through them, or PayPal or your bank.
If there was a way to break into the phones while retaining full functionality I'd be all over trying my hand at unlocking a few (recent, not the 11; 12 or newer) phones from each generation to see if it was reliable and basically get cheap iPhones like it's nothing. Apple has secured it such that even the most persistent among us don't even want to touch this beast because even if you bypass it the phone loses iMessage support, can't download apps, and cannot use FaceTime so you lose a LOT of functionality. In addition, if you ever forget the passcode and do not back up the SHSH blobs to keep it on old SW, the previous exploit may never work again and it's totally useless at that point. It just ain't worth bothering; I put these iCloud AL bum devices in the parts pile and call it a loss and try to reuse what I can (some parts are unreprogrammable, like FaceID modules; there's an eFuse on the module that blows so it's one shot field programmable and only Apple can do it). Other parts can be in some cases like screens, others are still somewhat unknown.
Indice 4
It’s basically a paperweight with limited parts that can be used again.
Indice 2
you will need to contact the previous owner and have them login to the icloud account and remove the association, either on the phone itself, or via either www.icloud.com or appleid.apple.com.
beyond that there is no permanent solution.
yes, you will find services and software offering to remove icloud accounts, it's all BS. these "solutions" involve jailbreaking the phone then installing a "bypass". but the phone will not behave like a normal phone (if i'm misstating some of these items, i welcome correction as a am not a jailbreaking expert). you will likely have issues with downloading and installing apps, you may have issues trying to use the only on you cellular service account, you cannot do auto upgrades the IOS, your device becomes more vulnerable to malware/hacking, battery drain/usage increases dramatically, it makes the overall IOS environment less stable meaning more crashes, and if you do upgrade the IOS or reset the phone, you have to re-jailbreak it again.
using jailbreaking to "fix" an icloud account is like (you may be too young to actually relate to this) watching TV before they had remote controls. you want to change the channel or change the volume or adjust the rabbit ears, you had to get out out of your chair, walk to the tv and do so manually - every time. sure it all worked, but it was horribly inconvenient compared to what a modern day TV remote can do for you.
if anyone has a better analogy, i welcome input on that regard as well. :)
bottom line, the only way to properly remove it is to have the icloud account owner do it
Indice 1
3utools could maybe help but you need a PC running windows 10 or newer
have you tried restoring via itunes?
Also, if this is a ebay phone, you need to talk to ebay
if none of the above works, a logic board replacement might work
https://www.ebay.com/itm/155457261916?va...
Indice 0
3 commentaires:
sure i have an 3U want remove lock......
par
Have a :) ....................................
par
Downvoted for 2 big issues: Serialization makes board only impractical (and the boards can also be prone to "financed" IMEI#s which you do not know and eventually get blocked for bad debt and you're SOL, you don't have the IMEI# to check the status), in addition to the SW tools doing nothing. It hides the issue, but you have a tablet that behaves like a Palm Piot where app availability was abysmal as it required installation through Palm Desktop.
Yes, I am really that old where I was toying with hand-me-down Palm PDAs, BlackBerry phones, Windows Mobile and Windows Phone 8/8.1; I even ran a WP8 (Lumina 635, AT&T didn't update to 8.1 and you couldn't reflash it like you could reflash the old Motorolas if they had nonsense carrier restrictions -_-; you just had to SIM unlock it first as the unlock may not work if you didn't have the "virgin" carrier ROM) phone to bide time when my LG G4 decided to die. My Euro V3i had a flashed ROM (Edge Wireless) due to the seller having to do it being imported with an issue.
par
There is no way you can remove an iCloud Activation Lock. No software or website can do this.
Indice 0
Furthermore, I recommend reaching out to Apple directly or visiting an authorized service center for guidance on how to proceed to . They will be able to provide you with the necessary steps and options to unlock the device. regards : todaypatches
Indice 0
Ajouter une réponse
Patrick A sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 54
Total : 2,492
