Aller au contenu principal
Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
20 questions Voir tout
Dual hard drive installation issue with connector cable.
I'm trying to install a second hard drive in my mac mini and I am having a few issues getting things to fit. I think the connector cable that came with the ifixit kit may be too short or too long (depending on if I route it between or above the second hd.) I can force it to connect if I route the connector cable between the drives, however can't seem to line the antenna plate afterwards or close the machine up. The guide is very helpful - however becomes vague at towards the end re: how and where the second drive should fit. Does anyone have any tips or guidance?
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
Ajouter un commentaire
1 Réponse
Solution retenue
Can you physically put the cover back on without installing the cable at all (with the antenna plate in place)? if not you may have too big a drive (height).
I'm assuming you have the 2011 version Mac Mini
The ribbon cable is sandwiched between the HD's just in the corner as it then routes up to the main logic bd.
See Step29 3rd image: Installation d'un second SSD dans le Mac mini mi-2011
The ribbon cable should just make it without any excessive slack. The primary drive should be resting flat just above the 2nd HD.
See step 18: Installation d'un second SSD dans le Mac mini mi-2011
I suspect the 2nd drive below the primary drive is too big and is forcing the primary drive up preventing you to close the case. If you can get your hands on a Dial Caliper (metric) you could measure the height of the two drives. Your new drive should be no bigger than the Apple drive. Millimeters count here!
Indice 0
Ajouter une réponse
johneadams sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 939
