Aller au contenu principal
Frame holding the opening hinges broken
My laptop doesn't shut properly and if I force it, the hinges are likely to break etc. I took the laptop to a repair shop and they said the plastic frame that the hinges are secured onto is snapped internally and I would need to replace this. However, I can't seem to find this part anywhere. I sent the laptop to HP and they almost quoted the price of a new laptop to cover the cost of repair. I'm told the hinges are ok, but snapped plastic mount inside, the hinges wont work. The laptop is outside the warranty period :(
HP ENVY Laptop
Model 13-ba0006a
ProdID 133S7EA3#ABU
Product No: 00325-96694-87351-AAOEM (not sure if this is the part)
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
6 Réponses
Réponse la plus utile
Hi @manishv
Do you mean the lid cover or the top cover where the keyboard is located?
In any event here's the maintenance and service guide for the HP ENVY 13-ba0000 Laptop PC series laptops that will help.
On p.21-25 Item #2 you will find the HP part numbers for all the top cover models available for the laptop series. They are country specific because the keyboard is part of the assembly so if this is the part you need, ensure that you find the correct one. Usually the part number can be found somewhere on the underside of the top cover if you wish to verify. As you said, not cheap.
On p.28 Item #6 (but shown as Item #8 on p.27) you will find the HP part number for the lid cover.
Search online using the required part number only to find suppliers that suit you best.
The manual describes the necessary pre-requisite steps and the procedures to completely dis assembly it, so that you can replace any removable part listed in the manual.
Click on the arrow to the left of Removal and replacement procedures for authorized service provider parts in the left column of the manual and then click on either display assembly or keyboard/top cover depending on which you need to replace.
Indice 1
1 commentaire:
Hi @jayeff
Thank you for your prompt response the providing the link to the maintenance guide for this laptop. I think you're right, it must be the cover to which the plastic brackets and hinges are attached to. I will check and revert back once I've had a chance to check. Much appreciated :)
par
Hi,
I had the same problem. The left hand hinge on my HP laptop broke and this put the stress on the screen which then pulled apart its various layers. Repair shops said they couldn't help because they didn't have the parts for this model. I found a crude but effective way to solve the problem. I attached a mini glass clamp which is used for glass top tables. I attached the clamp to the left hand bottom corner of the screen and tightened it in with an allen key. Now the stress of opening doesn't flex and break the screen. It works fine, although the laptop does not close perfectly flush. The type of clamp used is shown in the link below.
https://www.dciron.co.uk/products/s4gc11...
Indice 1
This same problem happen to my laptop. I ordered the cover and hinges. which total cost was about £80 then I fix it myself.
Indice 1
Hey, I had this same issue on my laptop, (same model) I ended up using epoxy to glue the threaded inserts back in place, and I loosened up the hinge so it didn’t happen again. Not as ideal as replacing the whole part, but a lot cheaper. Worked quite well, just have to be more careful with it. I’m currently trying to deal with a separate issue, which caused me to stumble upon this thread.
Indice 0
1 commentaire:
Just had to make sure the epoxy doesn’t touch the motherboard. Could corrode the board or something
par
the problem is due to the hinge inserts being set in weak plastic.. over time they become fatigued.. there's loads of sketchy ways people have suggested fixing this on the internet - the only real way to fix it properly - is to order a new replacement palmrest (it will have the plastic supports and threaded inserts for the hinge) - then just transfer over the motherboard etc into the new palmrest.. before re-fixing the hinges - unwind them half a turn.. also fill in the gaps between the plastic mounts with epoxy to add a bit more reinforcement and you shouldn't have any problems in future.
Indice 0
Ok - so all my parts arrived for the repair today. I received a brand new palm rest (which comes with keyboard installed) and I also ordered a new back cover for the bottom as the existing one had seen some abuse (was dirty and dented as I loaned it to someone).
Overall not a bad job - I followed the service and maintenance guide here: h10032.www1.hp.com/ctg/Manual/c06271813....
it's not difficult - it's just a little time consuming and you need to be methodical.. a quick summary of what I did;
  1. removed back cover from laptop
  2. unscrewed screen hinges and removed display cable
  3. followed the maintenance and service guide r.e. stripping down (i.e. removed battery, speakers, fingerprint reader, etc)
  4. starting installing the removed parts in reverse order (trackpad, speakers, motherboard etc)
  5. installed screen hinge (after slackening off half a turn each side)
  6. installed new back panel
thought I'd share some photos:
Replacement palmrest (front):
Replacement palmrest (back - showing brass inserts - these are the parts that break off and are a failure part of these laptops):
Rear of laptop with back cover removed (you can see the damaged hinge locations in the top right and top left):
Transferring parts over between old and new:
Job finished and reassembled:
Indice 0
Ajouter une réponse
Manish V sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 25
Total : 1,137
