Aller au contenu principal
Processeur quad-core Intel Core i7 à 2,4 GHz, 2,7 GHz ou 2,8 GHz (Turbo Boost jusqu'à 3,8 GHz) avec 6 Mo de cache L3 partagé.
20 questions Voir tout
HDMI port not outputting. even when screen is disconnected
Hey guys,
I got a 2.4 GHz Retina 15" Early 2013 with a dead backlight. I disconnected the display and I'm trying to output through HDMI but the port itself does not work. I have a thunderbolt to HDMI adapter and it does work as it does output, but overtime it'll disconnect and I have to shutdown the laptop and power it back on for it to work again.
If anyone has a solution for this, please help me out. Thanks!
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
It sounds like the IO board may be failing. Check out this guide for instructions on how to replace it. If you think the adaptor you're using could be faulty, then I'd recommend trying to borrow a separate adaptor for testing, or taking the device into a repair store for testing. It might also be a good idea to inspect the interior of the device for other signs of damage—something like this could technically be caused by a fault on the main logic board as well. Good luck!
Indice 1
Ajouter une réponse
Marcus Spano sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 12
Total : 67
