Aller au contenu principal
Pour réparer ensemble - Je crée un compte
desktop hdd isn't getting recognized by system ( not showing)
my pc is very old
motherboard p7h55
seagate 1tb (old)hdd
intel core i5 cpu
so like past 3 months pc keeps bugging all the time
first os was running in this hdd - couldn't start always showed pc is under repair / fixing drive c: where i installed os
so i fixed it by running os on a different (not so new) hdd (now it works fine)
but now (old) hdd is not getting recognized by pc
should change to ssd
would i be able to recover my files from (*old)HDD
is it possible that old HDD is dead
should i change the motherboard ?
TIA
Répondre à cette question J'ai le même problème
Indice 0
3 commentaires
Hi @bigtrifles,
Can you hear or "feel" if the old HDD is spinning when you turn the PC on, assuming that it is still connected that is?
par
@jayeff yes, i do feel the hdd is spinning when it's connected
par
@bigtrifles
Does it show as being detected in BIOS? Scroll down to Section 2.3 sata connections
par
Ajouter un commentaire
3 Réponses
Réponse la plus utile
Based on everything you are describing, your motherboard is just fine and your HDD is on it's way out.
First off, if the HDD makes any clicks, pops, stutters, grinding, etc. noises, STOP USING IT IMMEDIATELY. That is a sound of mechanical failure, and it is your data being scoured from the platters and lost forever. The more of that noise you hear, the more data is permanently lost and can never be recovered.
I completely agree that you should change to SSD. Even at a budget of just $20-$25 you can get a reliable sata SSD to be your boot/OS drive. Even if you get the smallest one you can find for the lowest price, even something like a 128gb ssd will significantly increase the performance of your entire system and increase the longevity of your HDD. Remember, the HDD only wears out while it's being used. A boot drive HDD is wearing out any time your computer is turned on, but one used only for storage only wears out when you're accessing that storage.*
You can, in the meantime, do some tests on the old HDD. If you can get it recognized in cmd, you can do a SMART check on it to get a general idea. Macrium Reflect and AOMEI Backupper are both free programs I can recommend that can help copy data off of drives with more robustness than Windows' File Explorer offers, and there are dedicated file restore and recovery programs (the good ones cost money, be aware; any "free" program that promises to recover files that I've ever seen is a scam) that can do even more. So long as the computer can "see" the drive, even if it reports that the drive is not initialized or needs formatting, there is some chance that you can recover files.
At the absolute worst, you can always send it in to a data recovery specialist. This is expensive (usually starting about $250USD for simple cases and going up from there), but they can do more with physical repair than any software recovery can do. Also, check with your local computer repair place if they have any partnerships. For example, I partner with Drive Savers, and any time my clients send something in using my partner number, they save 10% and I get a 5% kickback for the referral, so your local shops will likely be happy to give you their referral if they have one.
Good luck!
*This is a simplification of the idea, but broadly true.
Indice 1
@bigtrifles the answer by @erelectronics is absolutely correct and appropriate. I just want to add another option that has worked for me a few times. This does not apply to drives that " if the HDD makes any clicks, pops, stutters, grinding, etc. noises, STOP USING IT IMMEDIATELY" This only applies to drives that are not having any mechanical (that make sounds) issues .
Common failure on those drives is actually the controller board. You can identify that board by simply looking at the numbers that are printed on it. You can replace those boards with, most of the time, readily available boards. It is not as complicated as it might sound, and a lot of data recovery use the same methodology. Check this guide Remplacement du contrôleur de disque dur Hitachi GST Deskstar HDS721010CLA332 to see how I've done it in the past.
If you have any issues identify your drive controller ertc. just post a couple of good images of your HDD (both sides including the board)with your question Ajout d'images à une question existante
Image iFixit
Tutoriel
Difficulté :
Très facile
2 - 5 minutes
Image Hitachi GST Deskstar HDS721010CLA332 Hard Drive contrôleurs
Tutoriel
Difficulté :
Modérée
20 minutes
Indice 1
You should be able to access your old files unless the hdd is totally dead. You’ll have to find a workaround to find the hdd. Go into your devices and see if it’s in there.
Indice 0
Ajouter une réponse
big trifles sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 25
Total : 301
