Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Voici comment réparer votre iPhone 14 Pro. Sorti le 16 septembre, le "plus petit" smartphone phare d'Apple est doté d'un écran OLED ProMotion de 6,1 pouces, d'une caméra arrière à triple objectif, de la 5G et de l'encoche interactive Dynamic Island autour de la caméra frontale et des capteurs supérieurs. Successeur de l'iPhone 13 Pro.
14 pro restarting randomly SMC PANIC - ASSERTION FAILED - BSC failure
14 pro randomly crashin and restarting , below is log
{"bug_type":"210","timestamp":"1969-12-31 16:11:18.00 -0800","os_version":"iPhone OS 16.5.1 (20F75)","roots_installed":0,"incident_id":"D97AD64D-EAF1-4524-A740-867851D18C24"}
"build" : "iPhone OS 16.5.1 (20F75)",
"product" : "iPhone15,2",
"socId" : "8120",
"socRevision" : "11",
"incident" : "D97AD64D-EAF1-4524-A740-867851D18C24",
"crashReporterKey" : "5708cca0163b1c9b29d59baa119fc997ba2e3190",
"kernel" : "Darwin Kernel Version 22.5.0: Thu Jun 8 17:15:47 PDT 2023; root:xnu-8796.122.5~1\/RELEASE_ARM64_T8120",
"date" : "1969-12-31 16:11:17.01 -0800",
"panicString" : "panic(cpu 0 caller 0xfffffff017bf04ac): SMC PANIC - ASSERTION FAILED: target\/d73\/target.cpp:265: 0, SMC BSC failure, spreadsheet ver(*10) 130\nS.sensor array 0 - 4 is 0x0, 0x80000, 0x0, 0x0, 0x0 \nF.sensor array 0 is 0x0\n\n - Misc(2) OUTBOX1 not ready\nASSERTION FAILED: target\/d73\/target.cpp:265: 0, SMC BSC failure, spreadsheet ver(*10) 130\nS.sensor array 0 - 4 is 0x0, 0x80000, 0x0, 0x0, 0x0 \nF.sensor array 0 is 0x0\n\n\nRTKit: RTKit-2062.122.2.release - Client: AppleSMCFirmware-3424.120.39.0.1.d73.REL\n!UUID:
Full log : https://pastebin.pl/view/5e3a972d
Répondu ! Afficher la réponse J'ai le même problème
Indice 4
3 commentaires
Hey! My iPhone 14 pro max got into water and I am facing the same issue. Did you managed to fix it chaging any part? Any flex? Or disconnecting something? Thanks!
par
Hi, the solution is to change proximity sensor.
par
Hi, I have this problem too. Can you please help me how to fix it. My iPhone 14 Plus is restarting very frequently.
{"bug_type":"210","timestamp":"2024-11-03 10:03:55.00 +0530","os_version":"iPhone OS 18.0.1 (22A3370)","roots_installed":0,"incident_id":"F48B52FD-DB19-4E54-B627-7FAFF6148BD1"}
"build" : "iPhone OS 18.0.1 (22A3370)",
"product" : "iPhone14,8",
"socId" : "8110",
"incident" : "F48B52FD-DB19-4E54-B627-7FAFF6148BD1",
"crashReporterKey" : "0be072e2150d270585baec8961b3b595715401d4",
"kernel" : "Darwin Kernel Version 24.0.0: Thu Aug 8 01:16:02 PDT 2024; root:xnu-11215.2.5~62\/RELEASE_ARM64_T8110",
"date" : "2024-11-03 10:03:55.39 +0530",
"panicString" : "panic(cpu 1 caller 0xfffffff0369d3144): SMC PANIC - ASSERT: target\/d28\/target.cpp:266: 0, SMC BSC failure, spreadsheet ver(*10) 40\nS.sensor array 0 - 4 is 0x0, 0x500000, 0x0, 0x0, 0x0 \nF.sensor array 0 is 0x0\n\n - Misc(2) OUTBOX1 not ready\nASSERT: target\/d28\/target.cpp:266: 0, SMC BSC failure, ………
par
Ajouter un commentaire
4 Réponses
Solution retenue
@flannelist Alisha, looking at this panic I see that the sensor code it's calling out is numbered 0x80000, which I assume is not the same as the 0x800 for the charge port assembly. It looks like they've got a 32 bit word and each bit turned on corresponds to an individual sensor, but at this point it doesn't look like we have any information on which sensor 0x80000 is.
Any idea where we could look for this information?
Update (06/30/23)
Okay, some news here; it looks like @tech_ni is on the right track here; according to repair.wiki, here's the definition for that sensor.
Alisha, maybe something to add to your Wiki page?
Update (06/30/23)
Ah, I see what's going on now. Repair.Wiki has codes for the iPhone 13 and 14, and it turns out the same problem has a different code on the two models. That's going to be fun to keep up with in the future.
Alisha, I've edited your Wiki to add that latest information; feel free to modify, accept or reject my changes as you feel appropriate.
Indice 7
5 commentaires:
@dadibrokeit THANKS I have been meaning to get around to that. I know the codes for 14 Series are different just wasn't sure if that had been sussed out yet. I know Jesse Cruz stays busy keeping a lot of the repair.wiki stuff up to date, so I would trust whatever is there.
par
Everything worked as advised once sensor is changed. Thanks
par
Which sensor did you change
par
@tapiwabynergy This entire thread has been about the proximity sensor, so I'm going to go with that.
iPhone 14 Pro Front Sensor Cable
par
FAILED: target\/d28\target.cpp:266: 0, SMC BSC failure, spreadsheet ver (*10)
40\nS.sensor array 0 - 4 is 0x0, 0x600000,
Pls does anyone has soln to this?
par
Had the same issue with an iPhone 14 Pro Max (same panic.full error)
The iPhone had been severely damaged after the customer dropped it. We got a new screen for it and mounted that, instead of the broken one and we couldn't understand why it kept overheating and shutting down, whilst providing us this error.
Turns out it happened because the front sensor wasn't connected. :) (Turns out it's quite important, even if you only want to pull out data from the iPhone.)
Now the data is out safe and sound!
Indice 2
2 commentaires:
I´m looking for hours for an solution and I am thinking why I get this error from panic log 0x80000 in a 14PM? And didn´t even connected this sensor - i ask myself the whole time.
Your last sentenced saved my day and Life :)
Exactly because I didnt connect I get this error!
I just wan´t to say a big THANK YOU!!! :-)
par
@estherfisc28456 I'm glad it helped! :-)
par
disconnect the proximity sensor and see if it changes
Indice 1
10 commentaires:
when i disonnected proximity sensor and attached , sensor got very hot and the plastic white thing got seperated. now i have to buy new sensor to see if that survives.
par
@manikanta9463 going by panic full analyses its to do with the proximity sensor
par
@manikanta9463 i edited your post and added the screenshot of panic full diagnosis
par
@manikanta9463 your date is showing decades of iphone release aswell
par
I will get new proximity sensor and check if its fixes the issue. but without proximity sensor , still the device is rebotting , is it common ?
par
Voir 5 commentaires en plus
it is sure the proximity sensor is the problem. thanks for the answers
Indice 0
Ajouter une réponse
Mani sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 14
7 derniers jours : 63
30 derniers jours : 309
Total : 34,717
