Aller au contenu principal
La Xbox Series X est la console de jeu 4K de nouvelle génération de Microsoft. La Xbox Series X est sortie en même temps que sa cousine, la console Xbox Series S, le 10 novembre 2020.
55 questions Voir tout
Can a standard ATX power supply be used with an xbox series X?
The xbox series x employs a 10 pin connector. I've seen that you can get 24 pin female to 10 pin male adapters would this allow you to use a PC power supply?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Using a 24-pin PC power supply to a 10-pin Xbox Series X adapter is technically possible, but not recommended for a few reasons:
  • The Xbox Series X has very specific power delivery requirements that a generic PC power supply may not meet properly. Things like the voltage, max amperage, 12V rails, etc. need to match Xbox specs.
  • The pinout and wiring between a PC and Xbox power supply are likely different. Just because an adapter fits, does not mean the wires route to the correct pins/contacts on both sides. Miswired connections can damage the console.
  • The Xbox power supply is designed for the dynamic power demands of the console. A generic PC power supply isn't optimized for the changing loads during gameplay.
  • It could potentially void any warranty and may not provide stable power delivery.
  • If there are any electrical issues, an incompatible supply increases the risks of problems or hardware damage.
While a 24-pin to 10-pin adapter may physically fit and supply power, it is not guaranteed to work properly or safely with the Xbox Series X in place of the official power supply. The console has very specific power needs that a generic PC power supply may not meet reliably.
Indice 3
2 commentaires:
While a agree that there should be caution when doing anything like this to avoid damage. I want to know if it is possible. I'm trying to find more technical information for example the pinout arrangement of the 10 pin header in the xbox series x. My reason for asking this question is because the Xbox series x power supply seems to be made from cheap materials and not reliable my second reason is for testing purposes to create a test bench for parts in order to test and repair them with a reliable power set up. Thank you.
par
@stephencadden post a picture of your board with this " the 10 pin header in the xbox series x" showing. We can possibly shed some light on this.
par
Ajouter une réponse
Stephen Cadden sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 36
Total : 135
