Series connection how do I go about it
How can i connect 2 or more solar panels together
Hi @inavelihall
Here's a link that describes how to and the reason for connecting solar panels in parallel, series and series-parallel connection.
Hopefully this is of some help.
Connecting two or more black solar panelss together is a common practice to increase the total power output of your solar system. There are two main ways to connect solar panels: in series and in parallel.
1. Series Connection:
2. Parallel Connection:
Here's a simplified example:
Series Connection:
Before connecting your solar panels, it's important to check the specifications of your charge controller and inverter to ensure they can handle the voltage and current of your solar panel configuration. Additionally, use appropriate connectors and cables to make secure and weatherproof connections. If you're unsure or have a complex setup, it's advisable to consult with a professional solar installer.
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 14
Total : 96
