Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Commercialisé le 24 septembre 2021, l'iPhone 13 mini est une version petit format de l'iPhone 13 et le deuxième iPhone mini. Il est muni d'un écran OLED 5,4 pouces, d'une puce A15 Bionic et d'une caméra arrière double.
iPhone 13 mini restarting, SMC PANIC - ASSERTION
Please help me with this error, i tried to reinstall the IOS but no changes.
It has a screen changed and the rear, front camera doesn't work. I bought today as it is.
Can be any chances by the screen causing restarts ?
I read some articles that can be the Charger cable flex thing or proximity sensor flex , but i'm not sure. :(
I disconnected the charger cable flex and keep restarting.
panic(cpu 0 caller 0xfffffff02b8469ac): SMC PANIC - ASSERTION FAILED: target/d16/target.cpp:263: 0, SMC BSC failure, spreadsheet ver(*10) 190
S.sensor array 0 - 6 is 0x0, 0x400, 0x0, 0x0, 0x0, 0x0, 0x0
F.sensor array 0 is 0x0
- Misc(2) OUTBOX1 not ready
Répondre à cette question J'ai le même problème
Indice 4
1 commentaire
what d u do?
par
Ajouter un commentaire
2 Réponses
Réponse la plus utile
There's a whole section on this panic on the iPhone Kernel Panics page, but in summary, you're on the right track.
Panic Assertion failed is usually related to some sensor that isn't checking in with the System Management Controller (SMC).
The unfortunate part is that the sensor in your panic points to an issue with the logic board. The x400 sensor is specific to the iPhone 13 mini. The logic board for any iPhone X or new (save the XR and the 2020 and 2022 SE variants) has a stacked logic board. It's really two separate boards sandwiched together.
The x400 sensor is on the bottom board. Usually something like that would be caused by bend, or substantial drop. There could be a break in the connection between the boards, or an issue with the bottom board itself. That will require soldering and some very specialized tools to repair.
If the device is still under warranty, be sure to check with Apple. If it's not otherwise damaged, this should be covered.
Indice 1
I phone ristarting for apple id se
Indice 0
1 commentaire:
@sibunarana, I'm afraid us english speakers aren't going to be able to make sense of what you've written. Go ahead and write in your native language with more description of what your phone is doing or not doing.
I gather your phone is restarting; is it doing it at three minute intervals? Have you checked the kernel panics wiki page for instructions on how to read the panic logs? If so, copy and paste or take a screenshot of the first page and post it here.
What do you mean by "apple id se"? Are you saying you have an iPhone SE? If so, which version; there are three, and we'd need to know which one you have. If it's a different model, we need to know that.
If you don't give us more to work with, eventually we'll just archive your question as unanswerable.
par
Ajouter une réponse
Banana Joe sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 28
30 derniers jours : 132
Total : 16,008
