Aller au contenu principal
Lancé le 4 novembre 2017. Modèles A1868, A 1901. Disponible avec GSM ou CDMA /  64 ou 256 Go / argent et gris sidéral. (Se prononce "iPhone 10".)
1181 questions Voir tout
Face ID not working, but all sensors functional
Hi, my front and back cameras stopped working, and got a Face ID unavailable related to TrueDepth camera pop-up. I assumed I had broken the back camera, as this happened immediately after I replaced the back camera due to a cracked lens.
So I swapped out the back camera module, which fixed the front camera as well. However, FaceID is still broken, and I get a "Problem detected with TrueDepth camera" in FaceID/Passcode Settings.
In JCID Repair Assistant, all of the sensors appear to be present. What else could be wrong? I replaced the screen (and moved over the sensor array) and battery in the past, and FaceID was fine. Is the back camera tied to FaceID?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi Henry,
I've been trying to learn as much as I can about Face ID and its repairs and related information, and to the best of my knowledge the rear facing cameras are not tied to the Face ID system and can be replaced at will without issue. In actuality, the front camera isn't tied to the logic board either, but is harder to replace by itself since it's mounted in that metal frame with the rest of the front camera assembly components, the dot matrix projector and the IR camera (both of which are paired to the motherboard).
I actually had a similar problem with the cameras not working, but in my case it turned out to be the IR camera that was causing the issue. Replacing the IR camera restored the function of the other two cameras, but of course that cost me Face ID.
So yeah, I don't have an answer as to what's up with the JCID software, but there are a lot of guides, techniques and troubleshooting information available for the iPhone X that you can look through to see if there's an answer.
I have the QianLi iCopy device myself, so I'm not up to date on the JC product, but there are a few people on here who do have the JC programmer and hopefully they can chip in.
Indice 1
Ajouter une réponse
Henry sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 25
