Aller au contenu principal
A 250GB 3.5" SATA Hard Drive released by Western Digital.
4 questions Voir tout
Hdd is not getting detected
When i turn on the pc harddisk turns on and then turns off after 10-15 seconds. I want to recover my data from that disk. I tried to contact manufacturers of that disk but they say that disk is a copy and not a genuine one. I also tried to connect that drive to other pc but there also not getting detected
What should i do ?
That data is very much important to me. Please help
Répondre à cette question J'ai le même problème
Indice 5
1 commentaire
I have already recovered some HD's by removing the electronic board and resoldering it with the hot air rework station.
par
Ajouter un commentaire
2 Réponses
Réponse la plus utile
@khushaldhumane explain to us what this means "they say that disk is a copy". There are two possible failures, The controller board or the mechanical part. If it is mechanical, you want to leave your hands off and send your drive for data recovery to a place that specialize in this. Those are not cheap.
For the controller issue, you could try to replace the controller board. I've done that a few times and successfully removed data from those drives. But, you will need to get the right board etc. Not always an easy find. Check this guide for what I am referring too,
Remplacement du contrôleur de disque dur Hitachi GST Deskstar HDS721010CLA332
If you need more info or guidance, post some good pictures of your board etc. with your Question. that way we can see what you see.
Ajout d'images à une question existante
Image iFixit
Tutoriel
Difficulté :
Très facile
2 - 5 minutes
Image Hitachi GST Deskstar HDS721010CLA332 Hard Drive contrôleurs
Tutoriel
Difficulté :
Modérée
20 minutes
Indice 1
I am also stuck in the almost same situation. In this case, put your HDD in the sun for around 1 hour, then let it cool down for 10 minutes, and then insert it. In some cases, the HDD is fully recovered, and in some cases, it shows up in your PC for around 5-6 hours or a day. I recovered my data with this method.
Indice 0
Ajouter une réponse
Khushal Dhumane sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 80
30 derniers jours : 341
Total : 1,488
