Une ligne rouge vertical tv westinghouse 4k intelligente
Ligne verticale rouge télé 50' intelligente 4 k
Cette page de diagnostic n'a pas encore été traduite en Francais, mais peut-être que vous y trouverez des astuces pour votre problème : Lines On TV Screen
@sonia35744 this will depend on what the line looks like. If it is a single thin line, it will most likely be a TAB error. If it is a large line it could be a board error or a failed Source driver ribbon. If you can, take some pictures of what your screen shows you and post that with your Question. Remove the back of your TV and take some good pictures of the boards. Also of the top of the LCD where there are two ribbon cables that will connect to the "skinny " boards" Use this guide for that https://fr.ifixit.com/Tutoriel/Ajout+d'i...
What you want to try is to remove the back of our TV. There will be two long, skinny boards that connect to the LCD screen with multiple ribbon cables. Those are fastened to the LCD via a special process. The bonding is what comes loose and creates those lines. While the TV is on, push gently on the ribbon cable in the exact location where you see the line on the screen. If that line disappears or changes, you know that this is the issue. Since it is a special process to attach those cables, DIY'ers like you and I can't fix it. Sometimes applying pressure between the ribbon cable and the plastic frame of the screen, will help. I have also fixed some of them by applying a piece of a thermal pad, which I folded over, and then used some strong adhesive tape to keep it in place.
Lets start with the pictures and then we can use those to work out the details. Also, let us know what model your TV is. It is not as difficult or cumbersome as I may make it sound ;-)
Translation
@sonia35744 Cela dépend de l'aspect de la ligne. S'il s'agit d'une seule ligne fine, il s'agira probablement d'une erreur TAB. Si c'est une grande ligne, il peut s'agir d'une erreur de la carte ou d'un ruban de pilote de source défectueux. Si vous le pouvez, prenez des photos de ce que votre écran affiche et postez-les avec votre question. Démontez l'arrière de votre téléviseur et prenez de bonnes photos des cartes. Utilisez ce guide pour cela https://fr.ifixit.com/Tutoriel/Ajout+d'i...
Ce qu'il faut essayer de faire, c'est d'enlever l'arrière de notre téléviseur. Il y aura deux cartes longues et minces qui se connectent à l'écran LCD avec plusieurs câbles en ruban. Ces cartes sont fixées à l'écran LCD par un processus spécial. Le collage est ce qui se détache et crée ces lignes. Lorsque le téléviseur est allumé, appuyez doucement sur le câble plat à l'endroit exact où vous voyez la ligne sur l'écran. Si cette ligne disparaît ou se modifie, vous savez que c'est le problème. Étant donné que la fixation de ces câbles est un processus spécial, les bricoleurs comme vous et moi ne peuvent pas résoudre le problème. Parfois, une pression entre le câble plat et le cadre en plastique de l'écran peut aider. J'ai également réparé certains de ces câbles en appliquant un morceau de tampon thermique que j'ai replié et que j'ai ensuite maintenu en place à l'aide d'un ruban adhésif solide.
Commençons par les photos et nous pourrons ensuite les utiliser pour régler les détails. Indiquez-nous également le modèle de votre téléviseur. Ce n'est pas aussi difficile ou encombrant que je le laisse entendre ;-)
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 9
Total : 45
