The volume is seems low despite being set to 99
I have a BOSE Wave AWR1-2W from 1993 and the sound is sounds good but the volume is pretty low seeming even when turned up to max volume. Is there a demonstration mode that can be turned on for this model that I can turn off? The speakers are presumably fine as there is no buzzing or anything. Seems like it might be a volume setting. Anyone have any ideas? Thanks!
@alex015 do you have this option on your Bose:
On the remote control, press and hold the Alarm Setup button until -SETUP MENU- appears on your Wave system display
Press and hold the Preset 1 button until -DEMO SETUP- appears
par oldturkey03
Hi @oldturkey03 ,
Thanks very much for this. I saw the set up menu instructions for other models but it doesn't seem to be an option on this model.
Still trying to toy with other buttons to see if I can get any kind of menu to appear.
par Alex015
@alex015 if it is not a menu issue etc. then the issue could most certainly be on the circuit board. I believe that your board has the Volume control IC U403 that is responsible for the volume. take a look around that and see if there are things that look well, odd :-) iFixit does allow you to ad images to your Question. Those are always helpful when looking at circuit boards etc. Ajout d'images à une question existante
par oldturkey03
