Aller au contenu principal
How to replace a faulty panel on this laptop?
Screen is flickering continuously on any position. I am currently using an external monitor via hdmi for viewing. Also, digitizer needs to be replaced also? I mean is it necessary when replacing the panel?
Thanks in advance
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Hi @pan64870
It could also be a faulty eDP cable (fractured in the hinge perhaps)
Here's the hardware maintenance manual for the laptop.
Go to p.73 to view the procedure to remove/replace the LCD panel (complete module includes the touchscreen)
Go to p.93 Item #2 to find the part number (FRU number) for all the panels compatible with the model. Note: A "T" in the name description for the panel indicates it is a touchscreen i.e. FHDT= Full High Definition Touchscreen, FHD = Full High Definition.
Search online using the part number only applicable to your laptop, to find suppliers that suit you best.
The eDP cable is Item #4.
Usually the part number is on the back of the panel if you wish to confirm that you're getting the correct one (also on the eDP cable somewhere as well)
Indice 1
Ajouter une réponse
Pan sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 81
