Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La Galaxy Watch Active2 est une montre connectée de Samsung Electronics. Son numéro de modèle est SM-R825, SM-R830 ou SM-R835 et elle a été commercialisée en août 2019. Réparer votre Samsung Galaxy Watch Active2 avec ces tutoriels.
The appearance of the word "reboot" after submerging it in water, and
I was swimming in the pool when the word 'reboot' appeared on the screen, and then the screen stopped working. I tried to restart it, but it was no use.
Note: Some time has passed since this incident.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
@abdullaziz85196 sounds to me like your watch may have taken on some water. I would treat it the same way as I would any other water immersed device.
The very first step I would take is to disassemble your watch. Use these guides Samsung Galaxy Watch Active2 to help you disassemble your smartwatch. Take a close look at all components and connectors. Check for major corrosion, evaluate the pins in the connectors etc,. If you need to use water to clean any gross contamination, use sterile water. Take a look at all connectors as well as cable ends. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but it is still pertinent to your watch as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. Also, you do not need to leave the parts to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. It would of course be best to get it professionally cleaned Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. After that, reassemble your smartwatch and re-evaluate.
Changement carte mère Samsung Galaxy Watch Active2
Changement batterie Samsung Galaxy Watch Active2
Image iPhone
Tutoriel
Réparer un dommage causé par un liquide sur un iPhone
Difficulté :
Difficile
1 - 2 hours
Image Samsung Galaxy Watch Active2 Carte mère
Tutoriel
Difficulté :
Modérée
35 minutes - 1 hour
Image Samsung Galaxy Watch Active2 Batterie
Tutoriel
Difficulté :
Modérée
40 minutes - 1 hour
Indice 0
Ajouter une réponse
Abdullaziz sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 27
Total : 368
