Aller au contenu principal
Samsung Galaxy Watch Active2 Motherboard Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Watch Active2 Motherboard Replacement, Turn off the watch: étape 1, image 1 de 2 Samsung Galaxy Watch Active2 Motherboard Replacement, Turn off the watch: étape 1, image 2 de 2
    • Turn off the Galaxy Watch Active2 by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears, tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
  2. Samsung Galaxy Watch Active2 Motherboard Replacement, Remove the rear screws: étape 2, image 1 de 1
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
  3. Samsung Galaxy Watch Active2 Motherboard Replacement, Separate the back cover from the housing: étape 3, image 1 de 3 Samsung Galaxy Watch Active2 Motherboard Replacement, Separate the back cover from the housing: étape 3, image 2 de 3 Samsung Galaxy Watch Active2 Motherboard Replacement, Separate the back cover from the housing: étape 3, image 3 de 3
    • Use an opening pick and place it between the plastic back cover and the metal housing near the buttons.
    • Push the opening pick into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
  4. Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the sensor array: étape 4, image 1 de 2 Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the sensor array: étape 4, image 2 de 2
    • Carefully lift the back cover to access the sensor array connector.
    • Use a spudger to disconnect the sensor array from the motherboard.
  5. Samsung Galaxy Watch Active2 Motherboard Replacement, Remove the back cover: étape 5, image 1 de 1
    • Remove the back cover.
  6. Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the display and speaker: étape 6, image 1 de 3 Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the display and speaker: étape 6, image 2 de 3 Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the display and speaker: étape 6, image 3 de 3
    • Use a spudger to disconnect the display assembly and the speaker.
  7. Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the barometric sensor, buttons, and mic: étape 7, image 1 de 3 Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the barometric sensor, buttons, and mic: étape 7, image 2 de 3 Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the barometric sensor, buttons, and mic: étape 7, image 3 de 3
    • Use a spudger to disconnect the barometric sensor, the buttons, and the microphone.
  8. Samsung Galaxy Watch Active2 Motherboard Replacement, Lift the core assembly: étape 8, image 1 de 2 Samsung Galaxy Watch Active2 Motherboard Replacement, Lift the core assembly: étape 8, image 2 de 2
    • Place a spudger underneath the motherboard at the top right next to the display connector.
    • Slightly twist and lever the spudger to loosen the core assembly.
    • It might help to also check the comments below this and the next step if you’re having difficulties.
  9. Samsung Galaxy Watch Active2 Motherboard Replacement, Remove the core assembly: étape 9, image 1 de 3 Samsung Galaxy Watch Active2 Motherboard Replacement, Remove the core assembly: étape 9, image 2 de 3 Samsung Galaxy Watch Active2 Motherboard Replacement, Remove the core assembly: étape 9, image 3 de 3
    • Grab the core assembly and carefully slide it out from under the cables.
    • Remove the core assembly.
  10. Samsung Galaxy Watch Active2 Motherboard Replacement, Flip the Core Assembly: étape 10, image 1 de 1
    • Flip the core assembly over so the motherboard faces down.
  11. Samsung Galaxy Watch Active2 Motherboard Replacement, Undo the top button: étape 11, image 1 de 2 Samsung Galaxy Watch Active2 Motherboard Replacement, Undo the top button: étape 11, image 2 de 2
    • Use the tip of an opening pick to peel the top button off the plastic frame.
  12. Samsung Galaxy Watch Active2 Motherboard Replacement, Remove the motherboard screw: étape 12, image 1 de 1
    • Use a Phillips screwdriver to remove the 4.4 mm-long screw holding the motherboard in place.
  13. Samsung Galaxy Watch Active2 Motherboard Replacement, Free the motherboard: étape 13, image 1 de 2 Samsung Galaxy Watch Active2 Motherboard Replacement, Free the motherboard: étape 13, image 2 de 2
    • Place the flat end of a spudger between the motherboard and the plastic frame near the copper coil at the bottom right.
    • Twist the spudger to free the motherboard from the plastic tabs.
  14. Samsung Galaxy Watch Active2 Motherboard Replacement, Remove the motherboard: étape 14, image 1 de 1
    • Slide the motherboard out from under the remaining plastic tabs to remove it.
4 autres ont terminé cette réparation.
Tobias Isakeit
Membre depuis le 03/31/14
118 058 Réputation
189 tutoriels rédigés
Équipe
Tobias Isakeit - Repairability Engineer Membre de l'équipe Tobias Isakeit - Repairability Engineer
Business
1 membre
1 086 tutoriels rédigés
13 commentaires
Hi, I am having issues with bluetooth, is it a replacement or do I need to swap the MB? Thank you
Bruno Albin - Réponse
When you have ruled out any software issues (tried restart, factory reset, software update, etc) then this is most likely a MB replacement since all the modules are integrated on that tiny thing.
Tobias Isakeit -
does the watch active have the same motherboard as the watch active 2
aqoullam6 - Réponse
Nope, the Watch Active has a different motherboard.
Tobias Isakeit -
My watch stopped vibrating all together, which part do I need to replace?
Melissa McEleney - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 27
30 derniers jours : 153
Total : 8,674
