Aller au contenu principal
Pour réparer ensemble - Je crée un compte
The Lenovo 300e is a convertible laptop and versatile learning tool that is powered by Intel. This device comes with a charger and 3 built-in USB ports.
Has anyone done a 300e Keyboard replacement?
Hey guys, Our school district has about 400 of these guys and I've seen a couple with bad keyboards. I'm guessing it's a bad ribbon cable but it's impossible to get to it as the keyboard is riveted to the frame. Any ideas?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Hi @clarareid
If it is only a few keys on the keyboard that are the problem it may be the key itself and not the keyboard per se.
There are suppliers¹ online that supply the keys for a lot of different models. You could always contact them first or maybe just get one set of replacements to see if replacing the keys resolved the problem.
¹Supplier example only - there are other suppliers, search online for laptop key replacement.
Indice 1
1 commentaire:
I have about 400 of these devices in my care. In an attempt to see what's up, I did take apart one of the keyboards completely. I suspect it is a fault in the ribbon where it joins with the keyboard (not the other end). Looks like the only real fix is to order a replacement Upper Case like @Ottobunnycoder mentioned.
par
You will probably have to end up replacing the whole upper case. If the whole keyboard isn't working, it could possable be the cable. If only a few keys aren't it would probably be a keyboard issue, or a keycap.
Indice 0
1 commentaire:
I have this problem as well in a similar fashion - for a school. I keep finding that N & B keys fail first. Are you finding this? Have you found any solutions with your keyboard problem? Thanks!
par
Ajouter une réponse
Jacob Creasy sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 32
Total : 731
