Aller au contenu principal
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
20 questions Voir tout
Upgrading NVme/SSD M.2
Hi there!
I am in the process of upgrading my Late 2015 27" iMacs hard drives and was wondering if it was possible to boot and run the computer on the M.2 SSD on the motherboard. Would this be possible?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Yes! What you likely have currently is a Fusion Drive, this config uses both drive connections. You will need to replace both drives and then depending on your needs put in fresh drives either just one or two (PCIe/NVMe or SATA)
But before you do that you need to fully backup your stuff, create a bootable OS installer USB thumb drive with the current or newer macOS you are planning on using (don’t exceed what is supported).
Now a warning - Please don’t install an M.2 SSD while some have achieved that the dependability has proven not to be stable. Stick with either a real Apple SSD or OWC pin compatible Aura SSD.
Then use your created OS installer drive to prep your drive/s as the internet recovery option won’t offer you the correct version if you are running anything newer than Sierra which is the last version that uses HFS+ volumes, today Apple uses APFS.
Indice 1
Ajouter une réponse
Z S sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 52
