Why is my dryer not heating up.
I replaced the heating element in my dryer and it did fine on the first load of laundry but it isn't heating up again.
Hi @jake98574
Here's the wiring diagram for the dryer that may help.
There are two thermostats and a fuse in the heater's operating circuit so you may have to check all of them.
If they all test OK have you checked that there is 240V AC i.e. 2 x 120V AC at the wall power outlet that the dryer is connected to or that the allocated dryer fuses in the house power box are OK? The dryer needs a 240V power supply to work. One 120V supply for the motor and controls and the other 120V supply for the heater.
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 39
3 commentaires
@jake98574 what is the exact model for your dryer? Besides replacing the heating element what else did you check?
par oldturkey03
@oldturkey03 the model is a WED4850BW0. the coil for the element had a break in it and the thermostat that is attached was showing it had continuity before I put it on the new element
par jake
@jake98574 can you check again and see if your heating element still shows continuity and if the thermostat still has continuity as well?
par oldturkey03
